1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: STATIC softIOC
To: <[email protected]>
Date: Thu, 3 Feb 2005 11:49:24 -0500
I'm trying to make a deployable, STATIC build of a soft IOC application for Linux. In base 3.14.7 I edited configure/CONFIG to use STATIC=YES. Then I made an 'example' application using makeBaseApp.pl -t , then again with -i -t. Finally, I copied the app directory to another Linux computer, which doesn't have base.
When I start the soft IOC task, AND when the database has an INP field linked to a separate IOC, I get the warning "The executable "caRepeater" couldn't be located", about a minute later the IOC console displays "CA client library is unable to contact CA repeater after 50 tries.", then no more errors. All the while the record with the INP link is working.
Other than copying the base/bin and lib dirs to the target machine and incorporating their paths, is there a method to get the caRepeater (et al) included in the application's bin/lib? My old vxWorks IOC's have the caRepeater task bundled in (somehow).
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477 FAX 3030
RE: STATIC softIOC Jeff Hill
Prev: RE: R3.14.7 next build error ?! Jeff Hill
Next: RE: STATIC softIOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: R3.14.7 next build error ?! Ralph Lange
