1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants?
To: TECHTALK <[email protected]>
Date: Tue, 08 Feb 2005 13:50:53 +0100
Hi all,
I have some driver software that contains
double scan_period;
scan_period = 0.05;
The function is executed from startup script, i.e. the executing task is a floating point task.
However, sometimes when booting R3.13.2, the ioc crashes with "floating point underflow" while executing
printf ("init_record_generic: scan_period=%f\n", scan_period);
I couldn't even look at the registers, because ti also crashes when it tries to print the register containing scan_period.
According to the bitpattern, scan_period is not 0.05, but some denormalized value.
Even more astonishing is that the error only happens sometimes! In rare cases, everything is OK. When I boot R3.13.5, also everything is OK. I have compared the driver library compiled for both EPICS versions. It is exactly the same object code.
We load the driver library in the startup script. Maybe there is something wrong with the ld command, corrupting constants?
But how can this depend on the EPICS release? Maybe the code is loaded to another location, but does the location matter?
Why does this only happen with one driver?
Any ideas or solutions?
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
RE: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Lawrence T. Hoff
RE: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Jeff Hill
Prev: Re: Question about length of PV names Marty Kraimer
Next: RE: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? Lawrence T. Hoff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
