1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Browsing the ioc error log file
To: Ned Arnold <[email protected]>
Cc: APS tech-talk <[email protected]>
Date: Wed, 09 Feb 2005 19:22:32 +0100
Ned Arnold wrote:
I was wondering if anyone has found a free tool (or built one) that provides helpful filtering, sorting, perusing, processing of the standard ioc error log file ... i.e. a good noise filter.
Ned
Hi Ned,
I wrote a small tcl/tk application to browse those log files. I guess you can easily adapt it to your local environment.
Have a look at: http://people.web.psi.ch/luedeke/tmp/iocLogBrowser.tcl
You need to specify your logfile path and a file prefix if you deal with several log files of different types, e.g. of different networks. Both are defined at the beginning of the file.
The program provides searching and filtering by regular expressions for:
   * Message pattern
   * IOC pattern
   * Date Ranges
For log files <1MB it works ok; for bigger files filtering get's a bit slow.
I hope it is useful to you.
Andreas
Dr. Andreas Luedeke, SLS Operations Manager, Tel:+41-56-3104002
mailto:[email protected], http://people.web.psi.ch/luedeke
Browsing the ioc error log file Ned Arnold
Prev: Re: compiler bug in gcc version 2.8.1 (Tornado1) for PPC corrupts floationg point constants? J. Frederick Bartlett
Next: Re: Browsing the ioc error log file Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Browsing the ioc error log file Ned Arnold
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
