1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Gateway Build for 3.14.7
To: "Paul Sichta" <[email protected]>, <[email protected]>
Date: Wed, 2 Mar 2005 11:20:50 -0500
Oops, let me try gateway Beta12.
-ps
----- Original Message ----- From: "Paul Sichta" <[email protected]>
To: <[email protected]>
Sent: Wednesday, March 02, 2005 11:02 AM
Subject: Gateway Build for 3.14.7
I can't build the gateway (2.0.0Beta8) under 3.14.7. It builds fine for me using 3.14.6. OS is Linux RHEL WS-3, update 4. The errant output is listed below.
Has anyone else built the gateway with 3.14.7 under Linux? Any explanation for the errors?
... previous 'good' output snipped ...
-ansi -pedantic -Wtraditional -D_POSIX_C_SOURCE=199506L -O3 -Wall -Wmissing-prototypes -Woverloaded-virtual -Wwrite-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -D_X86_ -Dlinux -mcpu=pentium -fPIC -D_REENTRANT -DUNIX -D_BSD_SOURCE -DEXPL_TEMPL -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/epics/release/epicsR031407/base/include/os/Linux -I/home/epics/release/epicsR031407/base/include -c ../gateAsyncIO.cc
In file included from ../gateAsyncIO.cc:24:
../gateResources.h:110: `FILE' was not declared in this scope
../gateResources.h:110: `fp' was not declared in this scope
../gateResources.h:110: variable or field `setPutlogFp' declared void
../gateResources.h:110: syntax error before `{' token
../gateResources.h: In member function `void gateResources::setReadOnly()':
../gateResources.h:72: `ro' undeclared (first use this function)
../gateResources.h:72: (Each undeclared identifier is reported only once for
each function it appears in.)
../gateResources.h: In member function `void gateResources::setEventMask(long
unsigned int)':
../gateResources.h:77: `event_mask' undeclared (first use this function)
../gateResources.h:78: `event_mask_string' undeclared (first use this function)
gateResources::setConnectTimeout(long int)':
../gateResources.h:86: `connect_timeout' undeclared (first use this function)
... remainder snipped ...
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477 FAX 3030
Gateway Build for 3.14.7 Paul Sichta
Prev: Gateway Build for 3.14.7 Paul Sichta
Next: Re: Gateway Build for 3.14.7 Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
