1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dm and edm problems with CA gateway
To: "Kenneth Evans, Jr." <[email protected]>
Cc: "'tech_talk'" <[email protected]>
Date: Sat, 05 Mar 2005 14:05:03 -0500
>>> On 3/4/2005 at 18:16:49 CST, Kenneth Evans, wrote:
  > The numbers in camonitor stayed in range.
  > However, the PV did get set to DRVH or DRVL sometimes
If you have DRVH/DRVL set, you will never see a value exceeding them on a
monitor.  The value will be constrained to those limits (in convert())
before monitor() is called.
To test for these large, random values you should have DRVH=DRVL so the
limits are not used.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Re: dm and edm problems with CA gateway Kenneth Evans, Jr.
Prev: Re: dm and edm problems with CA gateway Rolf Keitel
Next: Who is using what EPICS version John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dm and edm problems with CA gateway Kenneth Evans, Jr.
Next: RE: dm and edm problems with CA gateway Kenneth Evans, Jr.
