1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA gateway failure
To: "'tech_talk'" <[email protected]>
Date: Tue, 22 Mar 2005 09:09:17 -0700
Hello All,
Sorry about the delay, I have been tied up with travel to the APS
and the SNS over the last two weeks.
This message is relevant to a CA gateway failure reported by Rolf
Keitel (Mantis Entry 113). The symptom observed was a corrupt
value written through the CA gateway when it is under a heavy
client induced write through load. The bug has been isolated to
the portable CA server. An incoming payload for a CA put was byte
swapped twice when an IO operation was restarted due to heavy
client loads.
I have committed a fix to CVS. This fix should appear first in
EPICS R3.14.7.
It will be important to *not* enable writes through your gateway
until you receive a patch for this bug.
Thanks to Rolf Keitel, Ralph Lange, and Ken Evans for their
assistance with this matter.
Sorry about any inconvenience that this has caused.
Jeff
> -----Original Message-----
> From: Kenneth Evans, Jr. [mailto:[email protected]]
> Sent: Monday, March 14, 2005 1:02 PM
> To: 'tech_talk'
> Subject: RE: dm and edm problems with CA gateway
> I thought Jeff would respond to this topic, but since he has
> not, let me say
> he was at ANL last week for another reason, and we traced the
> problem to the
> fact that CAS is swapping the byte order each time the request
> is sent.
> This causes it to be garbage every other time when it is (1)
> postponed on
> (2) machines that do not have network byte order (e.g. Linux).
> That it has not happened more often is because there is usually
> no need to
> postpone write requests.  A slider on a fast machine can cause
> it to happen,
> however.
> It will be fixed in base at some point.
> 	-Ken
Re: CA gateway failure Andrew Johnson
RE: dm and edm problems with CA gateway Kenneth Evans, Jr.
Prev: RE: Allen Bradley driver on Solaris Wayne Dahl
Next: Support for room temperature and humidity sensors J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: dm and edm problems with CA gateway Kenneth Evans, Jr.
Next: Re: CA gateway failure Andrew Johnson
