And then there is Mantis #176 for which the solution is known (and easy) and
Mantis #181, which should be easy. To say nothing of my favorite, #111,
which can't be that hard and which has a very substantial impact. All of
these should be included in a 3.14.7 patch.
It is difficult for me to patch base and test because I need to make both
Release and Debug builds on four platforms, then manage these builds and the
many extensions for which I am responsible. I prefer to rebuild my base as
seldom as possible, since it is so time consuming. I would expect others do
not want to have to keep installing patches, either.
I believe Jeff means #187 instead of #113 for Rolf's bug. I have tested
Jeff's changes for this bug, and they appear to work. I have not, of
course, tested them as included in a patch.
I am intending to try to find ways to fix #113 in the Gateway (or else
demonstrate that it cannot be fixed in the Gateway, whichever happens). I
just need to find time.
For those that can't remember what the numbers mean:
#176 'bad resource id' message in GW log file (owing to blocking socket)
#181 ca_host_name() now returns the host name of the client, not the
host:port of the server
#111 non-preemptive clients disconnect if ca_poll() isnt called regularly
(even though the server and network connection is ok))
#187 spurious corrupted value when writing through the gateway
#113 FATAL: exception not rethrown message when gateway killed with SIGTERM
on Solaris (and related problems on Linux)
-Ken
Re: CA gateway failure Ernest L. Williams Jr.
Re: Support for room temperature and humidity sensors J. Lewis Muir
<2005>
2025
RE: Support for room temperature and humidity sensors Wayne Dahl
'type-punned pointer' warning patch Eric Norum
<2005>
2025
