Kate Feng wrote :
>I finally got around to compare the CA connect rate and catime between
>RTEMS-mvme5500 and vxWorks-mvme5500. The conclusion is that EPICS/RTEMS
>and EPICS/vxWorks is competitive to each other while tested under the
>same network setup.
My apologies for misspelling. I meant the catime test showed that
EPICS/RTEMS-mvme5500 and EPICS/vxWorks-mvme5500 are "comparable" to
each other while tested under the same network setup. They
showed similar performance for 1K channels, but for the 10K channels
case, EPICS/RTEMS-mvme5500 shows higher performance. The test was
done in a very busy subnet.
Cheers,
Kate
RE: 3.14.6/asyn/vxi11 crash -- SOLVED Laznovsky, Michael
The later four ports of IP-Octal-232 could not work. ligang
<2005>
RE: CA Connect rates under RTEMS Feng, Shuchen
RE: CA Connect rates under RTEMS Kate Feng
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
