1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: The later four ports of IP-Octal-232 could not work.
To: "ligang" <[email protected]>, <[email protected]>
Date: Mon, 28 Mar 2005 07:23:35 -0600
Dear Li Gang,
Is your VIPC616 the standard board, or do you have the -01 option?  I believe that the standard board does not support one interrupt, which is used by the last slot (D).  At the APS we use the VIPC616_01, and I think it works fine with IP-Octal in any slot.
You can convert a standard VIPC616 to the -01 option yourself.  You need to wire-wrap some pins, and replace 2 PAL chips.  Marty Smith at the APS can provide you with the details on how to do this.
Mark Rivers
Sent: Monday, March 28, 2005 3:49 AM
To: [email protected]
Subject: The later four ports of IP-Octal-232 could not work.
Hi Everyone;
   I am using the IP-Octal 232 and VIPC616 carrier board, with drvAscii/drvSerial/tyGSOctal. There are four slots(A ,B ,C ,D ) in one VIPC616 and eight ports(a ,b ,c ,d ,e ,f ,g ,h ) in each IP-Octal 232. The communication is ok between IP-Octal 232 and other devices, when the IP-Octal 232 is put into slot A, or slot B ,or slot C of VIPC616. When the IP-Octal 232  is put into slot D of the VIPC616, The later ports(e ,f ,g ,h ) of the IP-Octal 232 doesn't work again, however,the first four ports(a ,b ,c ,d ) of IP-Octal 232 work well. I have exchange several IP-Octal 232 and VIPC616 respectively, the same errors will occur again.
   Is anybody could do help me? any adivce ia appreciated! Thanks in advance.
Li,Gang
Accelerator Control Group,
Accelerator Research Center
Institute of High Energy Physics (IHEP)
P.O. Box 918-10
Beijing, 100049
P.R. China
Tel:    +86-10-88235040 ext. 808
Fax:
    +86-10-88236190
E_mail: [email protected]
Re: The later four ports of IP-Octal-232 could not work. Martin L. Smith
Prev: The later four ports of IP-Octal-232 could not work. ligang
Next: RE: 3.14.6/asyn/vxi11 crash -- SOLVED Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: The later four ports of IP-Octal-232 could not work. Martin L. Smith
