1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Digitel MPC - TSP - RS232 Interface
To: "Owens, PH (Peter)" <[email protected]>, <[email protected]>
Date: Wed, 30 Mar 2005 12:29:06 -0600
Hi Pete,
We have support for the TSP function in the MPC using RS232.
It is included in the "ip" application in recent versions of the
"synApps" package.
http://www.aps.anl.gov/aod/bcda/synApps/ip/ip.html
The R2-4 release for EPICS 3.14.7, which uses "asyn 4-1" is available
now.
The R2-5 release for EPICS 3.14.7, which uses "asyn 4-2-1" will be
available next week.
Note that the required modules lists "ipac", but that is only if you
want to use the SBS IP-Octal serial module.  These releases will work
with any serial port that asyn supports, which includes local serial
ports on vxWorks, Windows, Linux and Unix, and TCP/IP terminal servers
on all platforms.
Mark Rivers
-----Original Message-----
Sent: Wednesday, March 30, 2005 10:48 AM
To: [email protected]
Subject: Digitel MPC - TSP - RS232 Interface
Has anyone out there used the Digitel MPC RS232 interface
to control the TSP functionality?
I have no problem with any of the ion pump commands,
but confusing things are happening when I try to
control the TSP - and in particular set it to timed mode.
(hex command 27)
Pete
Prev: Digitel MPC - TSP - RS232 Interface Owens, PH (Peter)
Next: Re: Logarithmic conversion / Breakpoint tabes Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: calcout ODLY field Geoff Savage
