Andrew Johnson wrote:
Liyu, Andrei wrote:
As I understand Application Developer's Guide 6.8 I can register
function and call it from iocsh (ioc shell).
Ok. I build IOC (windows, epics 3.14.7, MVC++.NET) from example
template. Start it ... get
">epics"
type "asSub" or "asSub()"
and read
"command asSub not found"
What is wrong?
A registrar(function) entry in a DBD file does not automatically
register a command with the IOC shell itself, it just arranges for the
named function to be called during the IOC's startup process. The
registrar function can then perform any actions you wish to take place
at that time, including registering new iocsh commands (for which you
have to provide additional information in C code).
See the various files in the <base>/src/iocsh/ directory for examples of
the command tables and the related call to iocshRegister() that you have
to make to add a new command. We really should have an example of how
to do all this in the example template, but we don't appear to at present.
There are tons of examples in synApps. Here's an excerpt from save_restore.c:
#include <epicsExport.h>
#include <iocsh.h>
int request_manual_restore(char *filename, int file_type); {
<code that implements the function>
IOCSH_ARG request_manual_restore_Arg0 = {"filename",iocshArgString};
IOCSH_ARG request_manual_restore_Arg1 = {"file_type",iocshArgInt};
IOCSH_ARG_ARRAY request_manual_restore_Args[2] =
{&request_manual_restore_Arg0,&request_manual_restore_Arg1};
IOCSH_FUNCDEF request_manual_restore_FuncDef =
{"request_manual_restore",2,request_manual_restore_Args};
static void request_manual_restore_CallFunc(const iocshArgBuf *args)
{request_manual_restore(args[0].sval,args[1].iva
void save_restoreRegister(void)
iocshRegister(&request_manual_restore_FuncDef,
request_manual_restore_CallFunc);
epicsExportRegistrar(save_restoreRegister);
The .dbd file specifies the registrar function as follows:
registrar(save_restoreRegister)
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
- ???registrar(function_name) Liyu, Andrei
- Re: ???registrar(function_name) Andrew Johnson
Re: building libraries from only objs and libs in 3.14 Benjamin Franksen
Re: Arbitrary Function Generator Steven Hartman
<2005>
2025
<2005>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
