Just example with some libraries.
Someone needs play with detector1, detector2, system4. He writes
something like
class CDetector1{
chid * pSCAIDParameter1;
evid * pSCAMonitorParameter1;
public:
CDetector1();
~CDetector1();
void vFDataProcessing(...);//work with detector
void vFGetData(...);//next layer get data
class CDetector2{){...}
class CSystem1{){...}
Program of next layer creates detector1, detector2 and system1 objects.
The layer is interested in data concerning to detectors and systems. It
wouldn't like to know anything concerning CA.
Have a good day, Andrei.
-----Original Message-----
Sent: Wednesday, April 13, 2005 6:29 PM
To: Liyu, Andrei; [email protected]
Subject: RE: CA; ca_context_destoy and CA channels
> So I open first thread, create CA context, create first
CA
> channel. Then I open second thread, attach to current CA
> context, create second CA channel. ... Then I decide to
> close first CA channel and close context (???!!!). What
> is behavior CA library? I suppose second CA channel will
> be closed without normal procedure of closing
> second channel + its monitor?
The 2nd channel's subscription (monitor) is removed from the IOC,
the channel is removed from the IOC, the circuit to the IOC is
disconnected, and the channel is attached to a NOOP CA service.
> But I don't like to close second channel and CA context!
> Then I should check is that channel latest (is the
> last channel)? I couldn't find suitable function in CA
> function API.
There isn't, currently, an interface for this information in the
library.
> I have once way - hold tracks of my CA channels (minimum
> is global counter). Usually it could be done. But if program
> is mixture of different libraries and each library comes to
> CA library then it becomes impossible.
No such interfaces (for attaching and incrementing an in use
count and detaching and decrementing an in use count) currently
exist. I will add your ideas to Mantis entry 161 (initiated on
behalf of Ben) for further consideration.
> But if program is mixture of different libraries and
> each library comes to CA library then it becomes impossible.
One would need to carefully consider if these independent
libraries should share a CA context. If so, perhaps you might
pass a CA context identifier to these libraries when they
initialize.
Jeff
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Monday, April 11, 2005 8:57 AM
> To: [email protected]
> Subject: CA; ca_context_destoy and CA channels
> Jeff,
> If I am not mistaken there are not couple features in
> current CA
> function interface.
> I can suppose that when you came to multithread CA you
> added
> get_current_context and attach functions. But there is not
> similar
> mechanism for ca_context_destoy.
CA
> context, create
> second CA channel. ... Then I decide to close first CA channel
> and
> close context (???!!!). What is behavior CA library? I suppose
> second CA
> channel will be closed without normal procedure of closing
> second
> Then I
> should check is that channel latest? I couldn't find suitable
> function
> in CA function API. Maybe get_current_context has something.
> But it is
> very deep.
> is
> global counter). Usually it could be done. But if program is
> mixture of
> different libraries and each library comes to CA library then
> it becomes
> impossible.
> Thanks,
> Andrei.
- RE: CA; ca_context_destoy and CA channels Jeff Hill
Re: CA; ca_context_destoy and CA channels Benjamin Franksen
Re: Possible bug in taskwd Kay-Uwe Kasemir
<2005>
<2005>
