Kate Feng wrote:
There are two network interfaces (N.I.) on my IOC, each attached
to a different IP address. I thought one could decide which medm
clients "Channel Accessing" which N.I. by opening two windows.
Both windows are set with EPICS_CA_AUTO_ADDR_LIST = NO.
Window #1 is set with EPICS_CA_ADDR_LIST= IP1, while
window #2 is set with EPICS_CA_ADDR_LIST= IP2.
Is ther any other better way ? I wanted to make sure that certain
clients CA the specified IP, instead of the other one. Thus, I
disconnected
one of the cable going to that specified N.I. However, when I do that,
all the medm clients on both windows became disconnected from the IOC.
The two IP addresses must be on different subnets, or the IOC OS's
network code is likely to just use one port for all communications to
that subnet - display the routing table from the IOC's OS and you may
get a clue what it's doing at the moment. Once you've separated the two
ports properly into different subnets, your technique of setting
EPICS_CA_ADDR_LIST should work as you expect.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: CA for IOCs w/ dual NICs Maren Purves
- CA for IOCs w/ dual NICs Kate Feng
RE: CA for IOCs w/ dual NICs Liyu, Andrei
RE: CA for IOCs w/ dual NICs Jeff Hill
<2005>
Re: CA for IOCs w/ dual NICs Ernest L. Williams Jr.
<2005>
