1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: build base 3.14.7 on Windows XP under cygwin
To: "Vladimir Sirotenko" <[email protected]>, <[email protected]>
Date: Mon, 16 May 2005 13:30:31 -0500
> I was using cygwin setup.exe version 2.457.2.2 to install cygwin on my
XP
I just upgraded my version of Cygwin to be the latest version of
everything, using the same version of the setup.exe as you.
I then executed the following script to define things:
$ cat /usr/local/bin/setup_epics
export
PATH="/usr/bin/:/usr/local/bin:/usr/X11R6/bin/:/corvette/usr/local/epics
/base/bin/cygwin-x86:
/corvette/usr/local/epics/extensions_devel/bin/cygwin-x86"
export EPICS_HOST_ARCH=cygwin-x86
export HOST_ARCH=cygwin-x86
I then went to the EPICS 3.14.7 base directory and did
$ make clean uninstall
$ make
It worked fine, I did not get any errors.
I am not using cygwin to cross-compile for any other architectures, I am
only using it to build for cygwin-x86 itself.  Are you using it to
cross-compile?
-----Original Message-----
From: Vladimir Sirotenko [mailto:[email protected]]
Sent: Thursday, May 12, 2005 4:18 PM
To: [email protected]
Subject: build base 3.14.7 on Windows XP under cygwin
I am trying to build base EPICS 3.14.7 on Windows XP using latest
version of cygwin and I just wondering if someone did it lately.
It looks like I am doing something wrong because what I saw was:
1) missing file README@vxWorks, I had to import it into the directory
base-3.14.7/src/makeBaseApp/top/exampleBoot/ioc from the internet
2) I had to remove line #25 (blank line) from
base-3.14.7/src/dbStatic/dbLex.l (otherwise compillation failed)
3) now I have problem with menuConvert.dbd in base-3.14.7/src/bpt
directory
$ pwd
/epics3.14.7/base-3.14.7/src/bpt
$ make cygwin-x86
make -C O.cygwin-x86 -f .../Makefile TOP=../../.. T_A=cygwin-x86
make[1]: Entering directory
`/epics3.14.7/base-3.14.7/src/bpt/O.cygwin-x86'
.../../../bin/cygwin-x86/dbToMenuH.exe .../menuConvert.dbd
.../O.Common/menuConvert
..h
Error "syntax error"  Last token "menu"
input line: menu(menuConvert) {
   in: file .../menuConvert.dbd line 10
db_parse returned -1
Terminal error For input file ../menuConvert.dbd
make[1]: *** [../O.Common/menuConvert.h] Error 255
make[1]: Leaving directory
make: *** [cygwin-x86] Error 2
Can someone give any hint?
Vladimir
Prev: Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
Next: Re: build base 3.14.7 on Windows XP under cygwin Vladimir Sirotenko
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: VxStats Rees, NP (Nick)
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
