1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SSCAN/SAVEDATA question
To: [email protected]
Cc: Tim Mooney <[email protected]>
Date: Thu, 09 Jun 2005 12:32:52 +0200
Hi All,
before we upgrade SSCAN record (or SynApps?) let me please ask 2 questions:
We are using SSCAN record version 5.12 together with saveData (synApps release 1.4 Jan2004) on EPICS 3.13.2
1) I observed that changing the STEP SIZE (or WIDTH?) to a negative value (you know the users do all kind of strange things) lead to the crash of the saveData task on the ioc.
2) When I put as an detector an array-valued PV, also confirmed by SSCAN message window, the saveData saves only zeros. The same happens if we specify GET-ARRAYS in the ACQ MODE for the detectors.
I'd be glad at the end to save 2D scans with array-valued PVs which I believe would be a perfect solution for the mXAS beamline.
_____
Swiss / / [email protected]
_/_/_/ _/ _/_/_/ /____ Beamline Controls Group
_/ _/ _/ Source / Paul Scherrer Institute _/_/ _/ _/_/ ____/ CH-5232 Villigen-PSI
_/_/Light _/ / Tel: ++41 56 310 5131
_/_/_/_/_/_/_/ _/_/_/___/ Fax: ++41 56 310 3151
Prev: Re: epics on ecos Noboru Yamamoto
Next: VDCT Support Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Porting db file generation from 3.13 to 3.14 Janet Anderson
