1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: LabVIEW RT interface with EPICS
To: Peter Horn <[email protected]>, [email protected]
Date: Fri, 10 Jun 2005 15:48:15 -0400
Peter,
            I suppose you asked about server (IOC) side.
Dave Thompson created Epics special records and API (library) that connect to the records. There are couple files that explain that (look on SM directory).
Wim Blokland created LabView’s wrapper for that library. Also he created some support VIs. One of them does DB for the special records.
About your second question.
At first, Windows is not Real-Time OS. So you couldn’t do normal Real-Time control system. But you could do pseudo Real-Time system. For example, I did tests with LabView program. Program lost events (ADC measuring ) on 85 Hz. On 60 Hz program lost some events (less than 10) during 24 hours. CPU loading was 70~80 %. If you will write more information maybe someone can help you more.
Good luck, Andrei.
-----Original Message-----
Sent: Thursday, June 09, 2005 5:17 PM
To: [email protected]
Subject: LabVIEW RT interface with EPICS
I just tried to post to the tech-talk group with my other e-mail address but it doesn't seem to have got through, so apologies if this comes up twice.
I'm doing a project where I need to connect to LabVIEW with EPICS. I know this has been done before in some capacity but I have a couple of extra problems. First of all I can't create a sample EPICS database for me to communicate to for testing during the development stage. I also will be connecting to the EPICS database through a Fieldpoint controller running Real Time, which - as far as I know - has not been done before.
If I can get a sample EPICS database to work with then I'll be on my way. I've tried some VI's that I downloaded to create one but couldn't get them to work. If anyone could help me out with creating one of these it would be much appreciated.
Best regards,
Peter Horn.
Yahoo! Messenger NEW - crystal clear PC to PC calling worldwide with voicemail
Prev: Re: epics on ecos Till Straumann
Next: Sorenson DLM16-250EM9E Power Supply john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: LabVIEW RT interface with EPICS Willem Blokland
Next: Invisible genSub record Eric Williams
