1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cygwin-x86
To: "Geoff Savage" <[email protected]>, "EPICS Tech-Talk" <[email protected]>
Date: Wed, 15 Jun 2005 10:04:55 -0500
Hi Geoff,
I've built 3.14.7 with a version of cygwin that was updated in the last month.
What versions of gcc andd g++ are you running under cygwin?
-----Original Message-----
Sent: Wed 6/15/2005 10:01 AM
To: EPICS Tech-Talk
Subject: cygwin-x86
When building for cygwin-x86 I ran into two errors, semi-colons that
were not expected by the compiler.  I built epics in the 3.14.7
directory and compared it to base-3.14.7 which is right out of the
distribution file.
diff -r 3.14.7/src/libCom/osi/epicsThread.cpp
base-3.14.7/src/libCom/osi/epicsTh
read.cpp
32c32
< void epicsThreadRunable::show ( unsigned int ) const {}
 > void epicsThreadRunable::show ( unsigned int ) const {};
Only in 3.14.7/src/libCom/test: O.cygwin-x86
diff -r 3.14.7/src/libCom/test/epicsListTest.cpp
base-3.14.7/src/libCom/test/epi
csListTest.cpp
192c192
I installed cygwin, epics base v3.14.7, set EPICS_HOST_ARCH to
cygwin-x86, and did a gmake cygwin-x86.  Any suggestions?
Thanks,  Geoff
Prev: cygwin-x86 Geoff Savage
Next: Re: problem during "make" Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Hytec DAC8402 Sibley III, Coles
