1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about Channel Archiver
To: huangsong <[email protected]>
Cc: [email protected]
Date: Thu, 23 Jun 2005 10:46:47 +0200
Is the time zone definition correct on the workstation that you run the ArchiveExport on? I.e. does the 'date' command print the correct time? Make sure that the environment variable TZ is set to the correct acronym for your time zone. (Or that /etc/localtime comtains the correct zone.)
Your examples look like TZ is used to determine the start time, but EPICS_TS_MIN_WEST is used to convert the timestamps of the exported data. I'm not sure if this is the expected or correct behaviour, though.
Hope this helps,
Ralph
huangsong wrote:
Hello,
I used ArchiveExport to retrieve archived data of Channel Archiver.
When I use "-start" option, the time specified was not corresponded with retrieved timestamp. For example:
If I specified -start "06/22/2005 03:00:00", it really retrieved data started from "06/22/2005 10:00:00".
If I change EPICS_TS_MIN_WEST, the only difference is that the timestamp of the retrieved data is different.
Why? I have defined EPICS_TS_MIN_WEST (-420) and EPICS_TS_NTP_INET (localhost) in $EPICS_BASE/config/CONFIG_SITE_ENV.
btw, EPICS is 3.13.8 Channel Archiver is 1.10.2
Best wishes and regards,
Huang song
IHEP
[email protected]
2005.06.23
Re: question about Channel Archiver huangsong
Prev: question about Channel Archiver huangsong
Next: Re: question about Channel Archiver huangsong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
