This is entry 208 in the bug tracker.
The intent was to declare these new operators private to prevent
accidental use of compiler generated defaults.
Jeff
-----Original Message-----
[mailto:[email protected]]
Sent: Tuesday, July 05, 2005 8:37
AM
To: [email protected]
Subject: EPICS 3.14.7 static
client build
I have built EPICS 3.14.7 for both linux-x86 and
hpux-parisc. I can build a Linux client successfully using either the static or
dynamic libraries. On the HP system, I can build with the dynamic libraries,
but not the static. I get linker errors stating that "tcpiiu::operator
new(unsigned long)" and "oldSubscription::operator new(unsigned long)"
are undefined. I looked through the code for "tcpiiu::operator
new(unsigned long)" and indeed found it in the class definition, but did
not find an implementation. I did find an implementation for "tcpiiu::
operator new(size_t, tsFreeList<class tcpiiu,32,epicsMutexNOOP> &)".
I am confused why the behavior of the linker differs from static and dynamic
build. Any ideas?
- EPICS 3.14.7 static client build Chris Slominski
RE: UDP send, errno=0x37 Jeff Hill
dynamic libraries location Christophe Moins
<2005>
2025
Re: EPICS 3.14.7 static client build Ralph Lange
maybe off topic, maybe not :-) Liyu, Andrei
<2005>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
