1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bacnet communication standard for building and automation
To: "'Olaf Krebs'" <[email protected]>, "'tech_talk'" <[email protected]>
Date: Fri, 8 Jul 2005 08:10:25 +1000
Yes,
As it happens I have a similar problem. While the Solution has not been
implemented yet, I am pursuing a BACNET/IP to OPC gateway/server (there are
several options here) and will then go OPC to Channel access. Check out
http://www-csr.bessy.de/control/SoftDist/OPCsupport/
You might like to check out some of the products at www.fieldserver.com.
Although I've not used personally used anything here, they seem to have a
useful number of options. BACNET itself comes in a variety of flavours- PTP,
MSTP, ARCNET and IP. We have BACNET/IP
Also, you might be interested in http://www.ethereal.com/. Ethereal is a
protocol analyser, has built in BACNET support and is open source.
I keep you informed of my progress if you wish.
Richard Farnsworth
The Australian Synchrotron Project
-----Original Message-----
Sent: 8 July 2005 1:40 AM
To: tech_talk
Subject: Bacnet communication standard for building and automation
Hello,
does somebody knows about activities  in the EPICS community  to use the
BACnet  communication standard to connect plants like air condition,
chiller, ...:
Bacnet:
*A Data Communication Protocol for Building Automation and Control
Networks*. Developed under the auspices of the American Society of
Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE), BACnet
is an American national standard, a European pre-standard, and an ISO
global standard.
written:
www.bacnet.org
Regards
Olaf Krebs
DESY
Bacnet communication standard for building and automation Olaf Krebs
Prev: EPICS <--> PS - Survey Martin Pieck
Next: Re: device support for SNMP Matthias Clausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Bacnet communication standard for building and automation Olaf Krebs
Next: Re: Bacnet communication standard for building and automation Rod Nussbaumer
