1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TSconfigure documentation
To: <[email protected]>
Date: Tue, 12 Jul 2005 16:35:56 +0100
I'd like to recommend a minor addition to the IOC Application
Developer's Guide. In section 7.6 on TSconfigure(), it is worth pointing
out that any changes you make with TSconfigure do not take effect unless
you also call TSinit() before calling iocInit. (This applies to R3.14.6
at least, probably others)
Many thanks to Steve Singleton for working out what the problem was.
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., RAL, Chilton, Didcot, Oxon, OX11 0DE
Tel: +44 1235 778511
Prev: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Next: Re: Bacnet communication standard for building and automation Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Next: Difference in shared library build between R3.14.6 and R3.14.7 Denison, PN (Peter)
