1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: msi command for building synApps 5.1
To: [email protected]
Date: Mon, 08 Aug 2005 16:51:44 -0500
Hello.
While trying to build synApps 5.1 with EPICS 3.14.7 on Red Hat Enterprise Linux WS v.3, it looks like it can't find a program called msi.
Does anyone know what msi is or where to get it?
If I comment out the vxStat and xxx modules in config/MASTER_RELEASE and config/Makefile it builds successfully.
To build, I did the following:
Edited config/MASTER_RELEASE to match my install locations and to fix the paths for the modules.
Edited motor/motorApp/Makefile to include the motors I wanted.
Downloaded and extracted the modules allenBradley v2-1, asyn v4-2-1, ipac v2-8, seq v2-0-10, and genSub v1-6.
Added a configure directory (and files) for genSub since it didn't have one.
Edited the configure/RELEASE file for all modules to have correct module paths.
Fixed TEMPLATE_TOP variable in love/configure/RELEASE.
$ cd config
$ make
Here's the actual error message:
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[4]: Entering directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db/O.linux-x86'
Inflating database from ../vxStats-template.substitutions using local rule
msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null
/bin/sh: line 1: msi: command not found
make[4]: *** [../O.Common/vxStats-template.db] Error 127
make[4]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db/O.linux-x86'
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db'
make[2]: *** [Db.install] Error 2make[2]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp'
make[1]: *** [vxStatsApp.install] Error 2
make[1]: Leaving directory `/opt/synapps-5_1/support/vxStats'
make: *** [/opt/synapps-5_1/support/vxStats.install] Error 2
Thanks!
-lewis
Re: msi command for building synApps 5.1 Ralph Lange
Re: msi command for building synApps 5.1 Marty Kraimer
Prev: RE: CA Errors, but everything works fine !!! Jeff Hill
Next: Re: msi command for building synApps 5.1 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
