1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: VxWorks - Timer Problem
To: <[email protected]>
Date: Fri, 12 Aug 2005 16:54:16 +0100
Title: Message
Hello fellow tech-talkers,
Apologies for not getting back to you earlier, many thanks for all the
smart suggestions concerning 'arrays in scripts'....problem solved.
I now have a problem setting up a timer in a driver, I used the functions
timer_create
timer_connect
timer_settime
When the interrupt occurs I get the error message...
interrupt: timerWdHandler: kill failed (timer=0x33a930, tid=0x5bba80,
errno=0x16).
I am pretty sure that it is the timer/interrupt as the message occurs
at the interval I set the timer for i.e. in tests so far once every 1 or 5
seconds.
I have trawled the internet and found this additional report....
saw anther scenario when I place the code in a driver. When I am
using the same functions(create,connect,settime) and I saw that in the
"kill fail" error message I get tid that I never had. So I made a
break point on timer_create and saw that timer_create is in a task I
didn't create. (On the break point I get t1 with the tid number I will
get in the kill fail message).
Do anyone know why after the connected function is done the task is
gone instead of returning to the place he was before the connect?
Anyone know the problem / fit ?
Extract from my code.....
static void RS485TimerInterruptHandler(timer_t timer_id, int arg)
    logMsg("TIMER id - %d arg - %d  !/n", (int)(timer_id), arg, 0, 0, 0, 0);
Extract from configure routine....
timer_t RS485TxHoldTimer;
/* Set Up Timer */
if (timer_create(CLOCK_REALTIME, NULL, &RS485TxHoldTimer) == ERROR)
       printf("timer_create() - ERROR/n");
if (timer_connect(RS485TxHoldTimer, &RS485TimerInterruptHandler, 1) == ERROR)
       printf("timer_connect() - ERROR/n");
DelayTime.it_value.tv_sec     = 1;
DelayTime.it_value.tv_nsec    = 0;
DelayTime.it_interval.tv_sec  = 1;
DelayTime.it_interval.tv_nsec = 1000000;
if (timer_settime(RS485TxHoldTimer, CLOCK_REALTIME, &DelayTime, NULL) == ERROR)
        printf("timer_settime() - ERROR/n");
Thanks
Darrell Nineham
Hytec Electronics Ltd.
Tel: +44 (0) 118 975 7770
Fax: +44 (0) 118 975 7566
Web: www.hytec-electronics.co.uk
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the sender immediately. The views expressed in the message are those of the individual author and may not necessarily represent the views of Hytec Electronics Ltd.
Re: VxWorks - Timer Problem Eric Norum
Prev: RE: Subversion Rees, NP (Nick)
Next: Re: VxWorks - Timer Problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
