Anyone have some advice for Chithra? It's been a while since I've thought
about StripTool or EDM.
Chris Larrieu
--- Chithra Karunakaran <[email protected]> wrote:
> Subject: FW: Font problem when using EDM
> Date: Mon, 29 Aug 2005 13:58:27 -0600
> From: "Chithra Karunakaran" <[email protected]>
> To: <[email protected]>
> Dear Christopher:
> I am developing EDM applications in a Linux machine. I am trying to
> open StripTool through shell command tool in EDM. But I get the
> following error:
> Representation size 80 must match superclass's to override font
> John Sinclair asked me to do the export LANG=C;edm but still I get the
> above error. Do you have any suggestions?
> Thanks,
> Chithra.
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: August 26, 2005 1:05 PM
> To: Chithra Karunakaran
> Subject: Re: Font problem when using EDM
> Chithra,
> Redhat 7.2 was the first to use UTF-8 rather than ascii. Try doing
> export LANG=C;edm
> The version of edm is found by doing
> edm -v
> When you run StripTool from the command line, do you get the same
> message?
> Also, see if your environment is significantly different when an edm
> invoked
> shell script is run; i.e. have the shell command do env. Then do the
> same
> command (env) from a terminal window.
> John
> On Friday 26 August 2005 1:51 pm, you wrote:
> > The simple shell commands work, like 'ls' and running '.exe' files.
> The
> > font problem comes only when I start the StripTool.
> > I tried in two machines with the following operating systems:
> > 1. Scientific Linux SL Release 4.0 (Beryllium) with openMotif
> > 2. Red Hat Linux release 7.2 (Enigma)with openMotif
> > The EDM version and StripTool versions are:
> > 1. EDM:???
> > 2. StripTool: CA v2.4.3, Linked with CA:4.9
> > I am not able to find the version of EDM.
> > Thanks for your help.
> > Chithra.
- Re: Fwd: FW: Font problem when using EDM Noboru Yamamoto
record reference manual Mark M. Ito
[no subject] Dalesio, Leo `Bob`
<2005>
2025
<2005>
2025
