1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: SNCSEQ...
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 1 Sep 2005 15:07:51 -0700
Hi all- we're trying to build a modified version of the SNC (state program compiler)
for local 3.14.6 development, and my attempts at making it use the test copy are falling short.
I've tried telling configure/RELEASE where the test compiler is via:
	#If using the sequencer, point SNCSEQ at its top directory:
	SNCSEQ=/u/cd/xyz/work/seq-2.0.10
... but the build fails with:
	gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure'
	perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease
	Definition of SNCSEQ conflicts with SNCSEQ support.
	In this application configure/RELEASE defines
	        SNCSEQ = /u/cd/xyz/work/seq-2.0.10
	but SNCSEQ at  has
	        SNCSEQ = <SLACstuff>/epics/R3.14.6/site
	gmake[1]: *** [checkRelease] Error 1
I don't see where the second definition in the error comes from.  It's not
anywhere in the installed EPICS area that I can find.
thanks,
Mike
Re: SNCSEQ... Ernest L. Williams Jr.
Re: SNCSEQ... Andrew Johnson
Re: SNCSEQ... Emmanuel Mayssat
Prev: RE: 3.14 build system doesn't cope with hyphens in IOC names Ernest L. Williams Jr.
Next: Re: SNCSEQ... Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
