Hi Andrew- Ernest helped me figure out that it was a mismatch between the SNCSEQ def in
configure/RELEASES in the app & local seq trees. The "<SLACstuff>" & xyz/ are just so I
wouldn't bore you with our local /afs paths; sorry about the confusion!
And there really is a gap in the "but SNCSEQ at has", but as that msg goes away when
I fix the RELEASEs, I don't know why that happened...
thanks for your help,
Mike
-----Original Message-----
Sent: Friday, September 02, 2005 7:45 AM
To: Laznovsky, Michael
Cc: EPICS tech-talk
Subject: Re: SNCSEQ...
Laznovsky, Michael wrote:
> gmake[1]: Entering directory `/u/cd/xyz/tmp-xyz/ioc/configure'
> perl <SLACstuff>/epics/R3.14.6/base/configure/tools/convertRelease.pl -h solaris-sparc checkRelease
> Definition of SNCSEQ conflicts with SNCSEQ support.
> In this application configure/RELEASE defines
> SNCSEQ = /u/cd/xyz/work/seq-2.0.10
> but SNCSEQ at has
> SNCSEQ = <SLACstuff>/epics/R3.14.6/site
> gmake[1]: *** [checkRelease] Error 1
> I don't see where the second definition in the error comes from. It's not
> anywhere in the installed EPICS area that I can find.
Is the text above *exactly* as reported by the tool, or did you edit the
two "<SLACstuff>" parts? I note that the second line above has
<SLACstuff> in the path to the convertRelease.pl script, and that looks
to be part of the problem. Check whether SNCSEQ (or SLACstuff even) is
found anywhere in your <base>/configure directory. Do you use an
automounter that uses soft links and gives different paths to mounted
file systems?
There should be a path printed in between the words "but SNCSEQ at" and
"has"; if that path really is empty it could be reading a file from the
root path /configure/RELEASE so have a look there too. Finally, I'm not
sure what will happen if the SNCSEQ installation itself has a definition
for SNCSEQ in its own configure/RELEASE file, so make sure there isn't
one set there.
Let us know what you find...
- Andrew
English arose from Normans trying to pick up Saxon girls.
Keithley 237 Luchini, Kristi
Call for Volunteers: 3.13 Record Reference Manual Andrew Johnson
<2005>
Re: SNCSEQ... Emmanuel Mayssat
archive viewer installation problem Christophe Moins
<2005>
