Hi, everyone!
I rebuilt AV with Java 1.4, so all problems should be gone now.
Sorry for inconvenience.
Sergei
Chevtsov, Sergei wrote:
Hi, Christophe!
Claude is correct, and I apologize for not testing the new build under 1.4 :-(
Unfortunately, I have no access to SNS CVS right now, so I will be able to fix it only when I am back from my vacation next Wednesday.
To all:
Btw, how many people still use Java 1.4?
Sergei
-----Original Message-----
Sent: Fri 9/2/2005 9:08 AM
To: Christophe Moins
Cc: [email protected]
Subject: Re: archive viewer installation problem
This looks very much like the xal.jar (and hence MessageCenter.class)
was built with JDK1.5, whereas you are compiling and building with
JDK1.4. I've used classes across the transition from JDK1.3 to JDK1.4
before without a problem, but it looks like there are more
incompatibilities between 1.4 and 1.5. It's nice that the compiler flags
it, but the error message is a bit obtuse.
SNS builds XAL with JDK1.5 now, so you either have to move up to 1.5, or
request a jar file built under 1.4. I'm not sure if they have coded in
1.5 specific features, so that may or may not be possible.
- Claude
Christophe Moins wrote:
Hello,
I am trying to install archive viewer but I have the following message
when I launch the ant command in Archiveviewer's top directory :
Buildfile: build.xml
-create_build_dir:
build_all:
[javac] Compiling 842 source files to /root/archiveviewer/build
[javac]
/root/archiveviewer/src/epics/archiveviewer/base/AVBase.java:25:
cannot access gov.sns.tools.messaging.MessageCenter
[javac] bad class file:
/root/archiveviewer/ext_jars/xal.jar(gov/sns/tools/messaging/MessageCenter.class)
[javac] class file has wrong version 49.0, should be 48.0
[javac] Please remove or make sure it appears in the correct
subdirectory of the classpath.
[javac] import gov.sns.tools.messaging.MessageCenter;
[javac] ^
[javac] 1 error
BUILD FAILED
/root/archiveviewer/build.xml:21: Compile failed; see the compiler
error output for details.
Total time: 18 seconds
Does anybody what's going on ?
Thanks
Christophe
- RE: archive viewer installation problem Chevtsov, Sergei
Controls Group positions at SNS Gurd, David P.
animation and 3-d Bob Dalesio
<2005>
Keithley 237 Luchini, Kristi
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
