1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Failure probing for event generator
To: [email protected]
Date: Thu, 22 Sep 2005 11:02:07 -0700 (PDT)
Hi Ge,
Three things I'd suggest (based on my experience with 100 series hardware):
1) make sure your EVG is properly "seated" in the crate. Even if LEDs are
on, I've found that board can be incorrectly seated. This happened with
64x VME crates.
2) ensure the top rotary dial is set to '2' and the lower rotary dial is
set to '0'
3) change your card number from '4' to '0' if you only have one EVG
Step (3) may not be necessary to get it working.
You need to get a '0' return code from EgConfigure before you can get
any further.
The same suggestions apply to EVR (rotaries at '1' and '8', change
card to '0'). For EVR only, check that jumpers are set to '5' as
is documented on the board itself.
Dayle Kotturi
LINAC Coherent Light Source
Stanford Linear Accelerator Center
On Tue, 20 Sep 2005, Lei Ge wrote:
> Hello,
> I'm testing the event generator EVG200, but my IOC failed to probing the
> event-generator board. Could somebody give me some suggestions? Thank you
> very much.
> EgConfigure(4,0x2000)
> value = -1 = 0xffffffff = prsrv_cast_client + 0xff0f7b3f
> ErConfigure(6,0x1800,164,5)
> cd "/home21/home/leige/epicsApp/dbd"
> value = 0 = 0x0
> dbLoadDatabase("baseApp.dbd")
> devApsEg: Failure probing for event generator... Card disabled
> devApsEr: Failure probing for event receiver... Card disabled
> value = 0 = 0x0
> dbLoadDatabase("evgevr.dbd")
> value = 0 = 0x0
> Best wishes,
> Ge
Re: Failure probing for event generator Korhonen Timo
Failure probing for event generator Lei Ge
Prev: Re: EDM <--> MEDM display-file translators Dayle Kotturi
Next: Re: EDM <--> MEDM display-file translators wether
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Failure probing for event generator Lei Ge
Next: Re: Failure probing for event generator Korhonen Timo
