Geoff Savage wrote:
I don't think the if_ei driver can use anything other than half duplex, so I suspect that's what you're getting anyway. Have you run ifShow on both sides of a transfer and examined the differences in values? Could this be anything to do with discarded packets? NFS is prone to delays if packets are lost, and this might be the issue. If so, try increasing the number of receive and transmit frame descriptors that the ei interface is initialized with. I believe you do that by editing the file target/src/config/usrNetwork.c and change the two "0" parameters in the #ifdef INCLUDE_EI section, which are described in the vxWorks manual under if_ei(1). I don't know what the defaults are for these that are used when you supply zeros, but in Tornado 2.x we use 32 tfds and 128 rfds here - experiment and see if this makes any difference. HTH, - Andrew -- English probably arose from Normans trying to pick up Saxon girls.
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
