I see the same behaviour when I try it in this way. Using screen with a
script that calls the ioc startup script works, as suggested by several
people.
$ cat ./st.screen
#!/bin/sh
./st.boot
$ screen ./st.screen
Thank you for all of the help.
Malcolm
Sent: 08 November 2005 17:23
To: Walters, M (Malcolm)
Cc: [email protected]
Subject: Re: Running softIoc's in the background
On Nov 8, 2005, at 11:12 AM, Walters, M (Malcolm) wrote:
I have been trying to run a Linux softIoc in the background by
using the
screen command. When I try to specify the startup script at the
same
time (i.e. "screen ./st.cmd"), the ioc starts but on any
caget/caput/...
command the screen terminates without any error message.
What happens if you specify the executable explicitly rather than
starting the executable from the script?
i.e.
screen /full/path/to/bin/linux-x86/iocExecutable st.cmd
If I start the screen and then run the startup script I don't
have any
problems. This problem occurs for every database we have tried.
Has
anybody else had any similar problems or any ideas what might be
causing
this?
We are running R3.14.7.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Running softIoc's in the background Kay-Uwe Kasemir
Re: Running softIoc's in the background john sinclair
<2005>
<2005>
