1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS-uC5282 build problem
To: [email protected]
Date: Wed, 16 Nov 2005 12:35:09 -0500
Dear All,
I am trying to build EPICS (3.14.7) for RTEMS-uC5282 on host linux-x86. However relatively early in the build process, after entering src/libCom/O.RTEMS-uC5282, I get an error.
The last part of make output is:
Installing shared library ../../../lib/linux-x86/libCom.so.3.14
ln -s libCom.so.3.14 ../../../lib/linux-x86/libCom.so
Installing html ../../../html//freeList/freeList.html
mkdir ../../../html
mkdir ../../../html/freeList
Installing html ../../../html//gpHash/gpHash.html
mkdir ../../../html/gpHash
make[3]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.linux-x86'
make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../.. T_A=RTEMS-uC5282 install
make[3]: Entering directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282'
make[3]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom/O.RTEMS-uC5282'
make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed by `inc'. Stop.
make[2]: *** [install.RTEMS-uC5282] Error 2
make[2]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/mnt/disk1/tmp/jad/epics/R3.14.7/support/base/3-14-7/src'
make: *** [src.install] Error 2
Any help would be appreciated. Thanks.
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Ithaca, NY
Prev: RE: Ethernet camera Aladwan Ahed
Next: RE: RTEMS-uC5282 build problem Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: availiabity EPICS serial RTU modbus driver Bruins, Stefan
