Stephanie,
You are right. It turns out that CONFIG.Common.RTEMS-uC5282 doesn't come
with the R3.14.7 distribution. I got it from cvs and build is now
proceeding. Thanks.
John Dobbins
Allison, Stephanie wrote:
Hi John,
make[3]: *** No rule to make target `../O.Common/osiFileName.h', needed
by `inc'. Stop.
I wonder if OS_CLASS is not being set to RTEMS for your build. Either your base/configure/os/CONFIG.Common.RTEMS isn't setting it (OS_CLASS=RTEMS has been removed?) or your CONFIG.Common.RTEMS-uC5282 file is not including CONFIG.Common.RTEMS or something of this nature.
Stephanie Allison
- RE: RTEMS-uC5282 build problem Allison, Stephanie
Re: Real time video with epics Kay-Uwe Kasemir
Next RTEMS-uC5282 build problem John Dobbins
<2005>
2025
<2005>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
