1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Writing to PVs
Date: Sun, 20 Nov 2005 19:25:17 +0800
Hello,
I compiled the following code but there were several errors and I don't know
how to solve those problems.
Here is the code:
#include "stdafx.h"
#include <cadef.h>
#define MAXLEN 20
#define POLL 1.0e-9
#define SHRT_DLY 0.1
#define LNG_DLY 0.25
struct Channel
    dbr_string_t name;
    chid chan;
    struct Channel *next;
    struct Channel *prev;
}*pFirst=NULL,*pLast;
void connect_handler1(struct connection_handler_args);
void connect_handler2(struct connection_handler_args);
void an_event_handler(struct event_handler_args);
struct Channel *search(char *Name);
int main()
    int status,i,j,k;
    dbr_float_t *pValue;
    dbr_string_t Value;
    dbr_string_t Name[MAXLEN];
    struct Channel *pCurrent;
    unsigned long Nelem;
    /*initialize Channel Access task*/
    SEVCHK(ca_task_initialize(),"Unable to initialize");
    /*Get channel names and establish connection for each.*/
    /*Allocat memory for first node, and then for each additional node*/
    /*after connection is established. Loop until user enters "quit".*/
    for(printf("Enter a channel name.\n"),
         pCurrent=(struct Channel *)calloc(1,sizeof(struct
Channel));
          gets(Name)!=NULL&&strcmp(Name,"quit")!
=0;
         printf("Enter a channel name or \"quit\" to stop.\n"))
          SEVCHK(status,NULL);
          ca_pend_event(LNG_DLY);
          if(ca_state(pCurrent->chan)!=cs_conn)
               printf("couldn't establish connection to %
s;ignoring\n",pCurrent->name);
          else
Channel));
    //Install a dirrerent connection handler on each channel.
     if(pFirst!=NULL)
          for(pCurrent=pFirst;pCurrent!=NULL;pCurrent=pCurrent->next)
               status=ca_change_connection_event(pCurrent-
>chan,connect_handler2);
               SEVCHK
(status,"ca_change_connection_event:couldn't change handler");
     ca_flush_io();
    //Loop until "quit" is entered. Get Channel name.
    //If found, prompt for values; else skip rest of loop.
    //Call ca_put_callback().
    for(i=0,printf("%s\n%s\n","Enter the PV's name","Enter \"quit\" to
stop");
          gets(pCurrent->name)!=NULL&&strcmp(pCurrent->name,"quit")!
=0;
          printf("%s\n","Enter PV name or \"quit\" to stop"))
          ca_pend_event(POLL);
          pCurrent=search(Name);
          if(pCurrent==NULL)
               printf("Cannot find channel name in list.
Disconnected?\n");
               continue;
          Nelem=ca_element_count(pCurrent->chan);
          if(Nelem==1)
               printf("Enter value.\n");
               if(gets(Value)!=NULL)
                     status=ca_put_callback
(DBR_STRING,//EXTERNAL TYPE
     pCurrent->chan,//chid
    Value,//string of value
     an_event_handler,//callback
    pCurrent/*user supplied address*/);
         else if(Nelem>1)
               printf("Enter up to %u values or q to
quit.\n",Nelem);
               pValue=(float *)calloc(Nelem,sizeof(*pValue));
               for(k=0;(j=scanf("%f",pValue+k))==1&&j!
=EOF&&k<Nelem;k++)
               j=getchar();
               status=ca_array_put_callback(DBR_FLOAT,//external
type
         Nelem,//no. of elements to be sent
         pValue,//array of vlaues
          ca_pend_event(SHRT_DLY);
    return 0;
void connect_handler1(struct connection_handler_args connect_args)
    //set point to user-supplied address
     pCurrent->chan=ca_puser(connect_args.chid);
    //if connect up, initialize list or add node
     if(connect_args.op==CA_OP_CONN_UP)
          if(pFirst==NULL)
               pFirst=pCurrent;
               pFirst->prev=NULL;
               pLast=pCurrent;
          pLast->next=pCurrent;
          pCurrent->prev=pLast;
          pCurrent->next=NULL;
          pLast=pCurrent;
         printf("%s is connected.\n",pCurrent->name);
    //if connection down print message .
    //this block is unlikely to ever be used.
     else
         printf("%s is not connected.\n",pCurrent->name);
     return;
void connect_handler2(struct connection_handler_args connect_args)
    struct Channel *pPrevious,*pNext;
    //if connection down, free memory of user supplied address,
    //and delete nodes from list.
     if(connect_args.op==CA_OP_CONN_DOWN)
          pCurrent=ca_puser(connect_args.chid);
               pPrevious=pCurrent->prev;
               pNext=pCurrent->next;
               pPrevious->next=pNext;
               pNext->prev=pPrevious;
               free(pCurrent);
         else if(pCurrent==pLast&&pCurrent!=pFirst)
               pLast=pCurrent->prev;
               pLast->next=NULL;
               free(pCurrent);
         else if(pCurrent==pFirst&&pCurrent!=pLast)
               pFirst=pCurrent->next;
               pFirst->prev=NULL;
               free(pCurrent);
         else if(pCurrent==pFirst&&pCurrent==pLast)
               pFirst=NULL;
               pLast=NULL;
               free(pCurrent);
         printf("%s:channel disconnected.\n",ca_name
(connect_args.chid));
    //if re-connected, re-allocate memory
    else if(connect_args.op==CA_OP_CONN_UP)
Channel));
          connect_args.chid->puser=pCurrent;
          strcpy(pCurrent->name,ca_name(connect_args.chid));
          if(pFirst==NULL)
               pFirst=pCurrent;
               pFirst->prev=NULL;
               pLast=pCurrent;
          else
               pLast=pCurrent;
         printf("%s:channel re-connected.\n",pCurrent->name);
     return;
void an_event_handler(struct event_handler_args handler_args)
     if(handler_args.status!=ECA_NORMAL)
         printf("channel %s:put operation not successful.\n",ca_name
(handler_args.chid));
          SEVCHK(handler_args.status,NULL);
     else
         printf("channel %s:put operation completed.\n");
     return;
connect_args.chid->puser=pCurrent;                using undefined type“oldChannelNotify”
pCurrent=ca_puser(connect_args.chid);           can't convert“void *”to“Channel *”
pCurrent->chan=ca_puser(connect_args.chid); can't convert“void *” to“chid”
I wonder how to solve it.
Thanks!
Prev: Re: Problem booting EPICS on RTEMS-uC5282 Till Straumann
Next: infrastructure questions rolf
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: RE: Writing to PVs Liyu, Andrei
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
