1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN command string with null character
To: "Bruins, Stefan" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 29 Nov 2005 09:28:18 -0600
On Nov 29, 2005, at 8:39 AM, Bruins, Stefan wrote:
One thing I did not made clear in the previous email: the idea is that the
device has to respond to the message.
Ahhh...
O.K.  a custom conversion routine is not adequate in this case.
My first idea was to use the GBIBREAD operation for that, but this type has
only got a conversion routine for the reply. I had taken a look to the
GPIBCVTIO type, but this is not a query->response construction.
Yes it is.  GPIBCVTIO is completely general-purpose.  Nick DiMonte's Tektronix oscilloscope support uses GPIBCVTIO.  I've included some sections of his code.
Here's an example of a GPIBCVTIO routine which sends commands and gets replies.
/* 180 : read ethernet name SI */
         {&DSET_SI, GPIBCVTIO, IB_Q_HIGH, NULL, NULL, 0, 100,
          getEthernetName, 0, 0, NULL, NULL, NULL},
static int
getEthernetName(struct gpibDpvt *pdpvt, int P1, int P2, char **P3)
    struct stringinRecord *psi= (struct stringinRecord *) (pdpvt->precord);
    asynOctet *pasynOctet = pdpvt->pasynOctet;
    void *asynOctetPvt = pdpvt->asynOctetPvt;
    int j;
    size_t ntrans;
    char cbuf[300];
    char make[12], model[12];
    char netName[40];
    if ((pasynOctet->write(asynOctetPvt,pdpvt->pasynUser,"*IDN?",
                                sizeof"*IDN?" - 1,&ntrans) != asynSuccess)
     || (pasynOctet->read(asynOctetPvt,pdpvt->pasynUser,cbuf,
                              sizeof cbuf - 1,&ntrans,NULL) != asynSuccess)) {
        recGblSetSevr(psi, READ_ALARM, INVALID_ALARM);
        return -1;
    cbuf[ntrans] = '\0';   /* Null-terminate reply message */
    /* do the checks in cbuf and optionally send the "ETHERNET:NAME?"
       using the write/read commands like above */
    if (( j = sscanf(cbuf, "%11[^,],%11[^,]", make, model)) != 2){
      printf("Scope ERROR: Scope ID scanned %d, min 2 needed. ID string = \n %s \n"
         , j, cbuf);
      return -1;
    if(TDS3000Debug) {
      printf("cbuf = %s\n",cbuf);
      printf("make = %s\n",make);
      printf("model = %s\n",model);
      printf("model[8] = %c\n",model[8]);
    if ( model[8] == 'B' || strstr(cbuf,"TDS3EM") != NULL ){ /* has ethernet option */
      if ((pasynOctet->write(asynOctetPvt,pdpvt->pasynUser,"ETHER:NAME?",
                                sizeof"ETHER:NAME?" - 1,&ntrans) != asynSuccess)
        return -1;
      sscanf(cbuf, "%39[^\n\r]",netName);
    else {
      sscanf(cbuf, "%18[^\n\r]",netName);
    strcpy(psi->val,netName);
    return 0;
Here's an example that handles binary data.  The readArbitraryBlockProgramData routine is part of the ASYN package.  Have a look at it to see how arbitraty 8-bit data can be transferred.
/* 19 : read waveform : WF */
        {&DSET_WF, GPIBCVTIO, IB_Q_LOW, "DAT:SOU CH1;:WAVFRM?",
            "%lf", 0, 32000, convertData, 0 ,0, NULL, NULL, NULL},
static int convertData(pdpvt, P1, P2, P3)
  struct gpibDpvt *pdpvt;
  int P1;
  int P2;
  char **P3;
  double        xIncr, xZero, yMult, yZero, yOff;
  int byte, bits, length, ptOff, width;
  char encode[20], binFmt[20], byteOr[20], idString[80], ptFmt[20], xUnit[20], yUnit[20];
  int len, i;
  size_t ntrans;
  struct waveformRecord *pwf= (struct waveformRecord *) (pdpvt->precord);
    gpibCmd *pgpibCmd = gpibCmdGet(pdpvt);
    if ((pasynOctet->write(asynOctetPvt,pdpvt->pasynUser,pgpibCmd->cmd,
                                      strlen(pgpibCmd->cmd),&ntrans) != asynSuccess)
     || (pdevSupportGpib->readArbitraryBlockProgramData(pdpvt) <= 0)) {
        recGblSetSevr(pwf, READ_ALARM, INVALID_ALARM);
        return -1;
  if (sscanf(pdpvt->msg, "%d;%d;%19[^;];%19[^;];%19[^;];%d;%79[^;];%19[^;];"
                         "%lg;%d;%lg;%19[^;];%lg;%lg;%lg;%19[^;];#%1d%n",
         &byte, &bits, encode, binFmt, byteOr, &length, idString, ptFmt,
         &xIncr, &ptOff, &xZero, xUnit, &yMult, &yZero, &yOff, yUnit, &width, &i
            ) != 17) {
    return -1;
  if(TDS3000Debug) {
      printf("%p, index=%d\n", (unsigned char *)&pdpvt->msg[0],i);
      printf("byte- %d, bits- %d, encode- %s, binFmt- %s, byteOr-  %s\n",
              byte, bits, encode, binFmt, byteOr);
      printf("length- %d, ptFmt- %s\n",
              length, ptFmt);
      printf("xIncr- %g\nptOff- %d\nxZero- %g\nyMult- %g\nyZero- %g\nyOff- %g\n"              , xIncr, ptOff, xZero, yMult, yZero, yOff);
  i += width; /* I should be pointing to the first data byte now */
  /* Copy waveform data from response buffer to waveform record */
  if(P1) {
      printf("%p, index=%d\n", (void *)&pdpvt->msg[0], i);
      printf("ptFmt - %s, length - %d\n", ptFmt, length);
      len = P1;   /* if P1 is non-zero, use it as length */
  else {
      len = length;
  memcpy((char *)pwf->bptr, (char *)&pdpvt->msg[i], len*byte);
  pwf->nord=len;
  return(0);
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
FW: ASYN command string with null character Bruins, Stefan
Prev: FW: ASYN command string with null character Bruins, Stefan
Next: results of server and database survey Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
