1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using subArray
To: Carl Lionberger <[email protected]>
Cc: [email protected]
Date: Wed, 30 Nov 2005 17:47:49 +0000 (GMT)
On Wed, 30 Nov 2005, Carl Lionberger wrote:
I think the thing to do would be to separate out the soft support for the subarray record from the rest of the record; it really is too closely coupled now. Then whatever buffering it uses to deal with the outside could be in the device support code which would be tailored as needed.
Should I take this as a hint that my hack is likely to come unstuck? In truth I'm tending back to using separate length and index controls managing standard waveform records, but it isn't that code's turn yet...
I took care to avoid tampering with epics itself, so the only change I've made is that my subArray init_record reassigns MALM to a much larger value. I haven't worked that code very hard yet, as other stuff has intervened, but at first glance it seemed to work ok.
Re: Using subArray Carl Lionberger
Using subArray Michael Abbott
Re: Using subArray Noboru Yamamoto
Prev: Re: Using subArray Carl Lionberger
Next: Re: Using subArray Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
