1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: EPICS Installer and Objective-C Framework for Mac OS X
To: [email protected]
Date: Tue, 06 Dec 2005 14:03:47 -0500
Sorry about the website link. It is apparently a frame so a little more navigation is necessary.
To download the EPICS installer and Objective-C framework for Mac OS X, pleas visit:
http://ics-web1.sns.ornl.gov/ and select "Software" from the menu on the left and then select "EPICS Installer".
I also want to offer my appreciation to those who provided the Mac OS X (a.k.a. darwin-ppc) port of EPICS. All I have done is organize the versions in a standard location, develop an EPICS Objective-C framework and package them up into a standard Mac installer.
thanks,
-tom
On Dec 6, 2005, at 1:18 PM, Steve Lewis wrote:
Took me a minute to realize I had to go to the "Software" page to find the other links.
I have created a standard Mac OS X installer for EPICS binaries and also a new Objective-C EPICS framework designed for easy integration with Cocoa based applications, tools, frameworks, etc. The installer will install both the EPICS binaries and the Objective-C framework. Two examples are provided which demonstrate both the power and ease of use of the new framework. Even if you don't use the framework, the installer is still useful as a quick way of getting EPICS on a Mac without having to recompile it for each user (not all EPICS users are developers).
I can provide the framework source to those interested. It is likely to be source compatible with GNU Step, so porting to other platforms should be easy.
This framework allows rapid development of rich Mac OS X applications integrated with EPICS.
You can find a link to the installer at:
and select the "EPICS Installer" link under the "EPICS" heading.
Be sure to read the "README" file before installing.
EPICS Installer and Objective-C Framework for Mac OS X Thomas Pelaia II
Prev: Re: can't connect to ArchiveDataServer Kay-Uwe Kasemir
Next: Re: can't connect to ArchiveDataServer Devin Bougie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: EPICS Installer and Objective-C Framework for Mac OS X Thomas Pelaia II
Next: can't connect to ArchiveDataServer Devin Bougie
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
