1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Ethernet/IP: writing zero to soft tags --- More Info
To: [email protected]
Date: Sat, 17 Dec 2005 17:00:56 -0500
Some additional info regarding this problem of writing to soft tags.
First, I should have made clear this has to do with bo records.
Second, if I compare a hardware tag and a soft tag I see that when they are read the hardware tag, e.g. Local:9:O.Data[0], is treated as a bit in an integer whereas the soft tag reads back as a boolean, value =255 or 0.
For EIP_verbosity=10 the following excerpt illustrates this, there is a record that references Local:9:O.Data[0] which results in the tag Local:9:O.Data being read back as a group of bits and a record that references the soft tag remote_reset_a and reads back the boolean value 255 ("on").
It seems to me that when I subsequently try to write a zero to the soft tag remote_reset_a, the value 255 is treated by the Ethernet/IP driver as a collection of bits, the lowest bit is set to zero to generate the value 254. This is then written and interpreted by the controller as "on". (?)
MR_Response:
    USINT service         = 0x8A (Response to S_CIP_MultiRequest)
    USINT reserved        = 0x00
    USINT status          = 0x00 (Ok)
    USINT ext. stat. size = 0
    2 subreplies:
Response #0 (Local:9:O.Data):
MR_Response:
    USINT service         = 0xCC (Response to CIP_ReadData)
Data (1 elements):
DINT 127
Response #1 (remote_reset_a):
MR_Response:
Data (1 elements):
BOOL 255
Dear All,
We have the following problem using Ethernet/IP device support (and EPICS R3.14.7) with an
Allen-Bradley ControlLogix PLC. We can write to hardware output tags (things like Local:9:O.Data[1])
just fine, however when we try to write to a soft tag, i.e. a controller tag or a program tag, we find
we can write a "one" but not a "zero".
There was a related thread in 2004, beginning with
http://www.aps.anl.gov/epics/tech-talk/2004/msg00636.php
but it wasn't clear to me whether this issue was resolved.
If I set EIP_verbosity = 10 and look at the output (see below) the only difference  between writing a
"one" and writing a "zero" is the data sent. In the case of writing a "one" the data sent is "ff",
when writing a "zero" the data sent is "fe".
Is it possible "fe" counts as zero for a hardware output but not for a "soft" tag?
Any advice or suggestions on how to further debug are welcome.
Thanks
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Write Zero Request:
epics>  ------------------- New Request ------------
EncapsulationHeader:
    UINT  command   = 0x6F (SendRRData)
    UINT  length    = 64
    UDINT session   = 0x12023400
    UDINT status    = 0x00000000 (OK)
    USINT context[8]= 'Funstuff'
    UDINT options   = 0x00000000
Send RR Data
    UDINT interface handle   0
    UINT timeout             0
    UINT count (addr., data) 2
    UINT address_type        0x00 (UCMM)
    UINT address_length      0
    UINT data_type           0xB2 (Unconnected Message)
    UINT data_length         48
MR Request
    USINT service   = 0x52 (CM_Unconnected_Send)
    USINT path size = 2 words
    Path: Class 0x6 (ConnectionManager), instance 1
    USINT tick time   = 10
    USINT ticks       = 240
    UINT message size = 33
    ... (embedded message of 33 bytes)
    USINT path_size   = 1 words
    Path: Port 1, link 0
Embedded Message:
MR Request
    USINT service   = 0xA (S_CIP_MultiRequest)
    Path: Class 0x2 (MessageRouter), instance 1
    UINT count 1
Request #0 (remote_reset_a):
MR Request
    USINT service   = 0x4D (CIP_WriteData)
    USINT path size = 8 words
    Path: Tag 'remote_reset_a'    UINT type     = 0xC1
    UINT elements = 1
    Data: 00000000 FE                                              - .
Data sent (88 bytes):
00000000 6F 00 40 00 00 34 02 12 00 00 00 00 46 75 6E 73 - [email protected]
00000010 74 75 66 66 00 00 00 00 00 00 00 00 00 00 02 00 - tuff............
00000020 00 00 00 00 B2 00 30 00 52 02 20 06 24 01 0A F0 - ......0.R. .$...
00000030 21 00 0A 02 20 02 24 01 01 00 04 00 4D 08 91 0E - !... .$.....M...
00000040 72 65 6D 6F 74 65 5F 72 65 73 65 74 5F 61 C1 00 - remote_reset_a..
00000050 01 00 FE 00 01 00 01 00                         - ........
Write One Request:
    UINT  length    = 64
Send RR Data
    UINT timeout             0
    UINT data_length         48
MR Request
    USINT ticks       = 240
Embedded Message:
MR Request
    UINT count 1
MR Request
    UINT elements = 1
    Data: 00000000 FF                                              - .
00000050 01 00 FF 00 01 00 01 00                         - ........
Re: Ethernet/IP: writing zero to soft tags --- More Info Kay-Uwe Kasemir
Prev: Ethernet/IP: writing zero to soft tags John Dobbins
Next: Re: Ethernet/IP: writing zero to soft tags --- More Info Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
