Hi Kay,
Thank you for your suggestion - it worked.
We have one more question. right now by doing:
[sysuser@sc XMLRPCServer]$ ./ArchiveDataClient.pl -u
http://sc.starp.bnl.gov/archive/cgi/ArchiveDataServer.cgi -k 1 -l
Channels:
Channel BoolPV, 03/05/2004 18:53:56.767577600 - 03/05/2004
18:58:51.901960000
Channel DTL_HPRF:Tnk1:T, 03/01/2004 17:28:00.035262000 - 03/29/2004
13:01:00.230310000
Channel DTL_HPRF:Tnk2:T, 03/01/2004 17:28:00.035262000 - 03/29/2004
13:00:00.031041000
Channel DTL_HPRF:Tnk3:T, 03/01/2004 17:27:59.985282000 - 03/29/2004
13:01:00.280299000
we do see all channels inside index file but once we try to run it with
ArchiveViewer and plot it gives the error message :
java.lang.Exception: Couldn't execute the archiver.values request
java.io.IOException: org.xml.sax.SAXParseException: expected Element
and in console: Fatal error parsing XML: org.xml.sax.SAXParseException:
expected Element
Any idea?
Bill && Yura
Thanks
-----Original Message-----
Sent: Sunday, December 18, 2005 7:53 PM
To: tech talk
Subject: Re: Problem with XML RPC
Hi:
Well, I assume that
'/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/index'
is actually an existing path & filename that you configured.
The error message indicates that your web server &
ArchiveDataServer are also OK, otherwise
you'd never get as far as that error message.
The web server runs your copy of the network data server
as "nobody" or a similar low-privilege user.
So the next thing to check would be that
/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/*
and all the directories in the path to ... DemoData
have 'r-x' access for "nobody" or whoever's configured
in your web server to run CGI code.
-Kay
On Dec 18, 2005, at 19:04 , Waggoner, Bill wrote:
> Hi All,
> We installed epics 3.14.8 with ChannelArchiver (compilled without
> any problems).
> The box is Scientific Linux SL release 3.0.5 (SL) with Apache/
> 2.0.46. We have a small problem with ArchiveDataServer -
> it's up and running but if we try to check the index file in the
> DemoData we run into the error message :
> [sysuser@sc ChannelArchiver]$ ArchiveDataClient.pl -u http://
> sc.starp.bnl.gov/archive/cgi/ArchiveDataServer.cgi -k 1 -m Ex
> Channels:
> Fault returned from XML RPC Server, fault code -601: Cannot open
> index '/home/sysuser/epics/extensions/src/ChannelArchiver/DemoData/
> index'
> Any suggestions?
> Thanks,
> Bill Waggoner && Yura Gorbunov
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.13.13/198 - Release Date:
12/12/2005
Internal Virus Database is out-of-date.
12/12/2005
Re: Problem with XML RPC Kay-Uwe Kasemir
RE: Problem with XML RPC Waggoner, Bill
<2005>
2025
<2005>
2025
