1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Variable scan rate
To: "Emmanuel Mayssat" <[email protected]>, "John Faucett" <[email protected]>
Cc: <[email protected]>
Date: Thu, 5 Jan 2006 09:08:16 -0800
Take a calcout record -----
>From the temperature controller - FLNK to an AO record that writes the index of
the .1 second menu item (is it a 3?) to the SCAN field of a calcout record
(thisCalc) that reads the temperature as follows:
INPA  temperature NPP
INPB  temperature PP
CALC  (A-B)<20?3:(A-B)<10?4:(A-B)<4?5:0
OUT	thisCalc.SCAN
This should change the SCAN field of this calc record - reducing it from .1
second, to .2 second to .5 second until it sets it back to Passive.
I'm not sure the application - but it seems ill advised to stop scanning the
temperature unless there is nothing else that would cause it to change. Isn't
there the possibility of a rupture - or sudden ice age onslaught like in the
movies?
Bob
-----Original Message-----
Sent: Thursday, January 05, 2006 8:45 AM
To: John Faucett
Cc: [email protected]
Subject: Variable scan rate
Hello ,
I would like to have a scan rate that works as follow:
( example: for temperature readback record)
The record starts in passive mode
When I change the temperature settings, the record should have a high scan rate.
When the readback stabilizes, the scan rate should decrease and after some amout of time go back to passive.
Did anybody implement this type of scan ?
If so how?
Emmanuel Mayssat
Cell: 650/793-0626
Lyncean Technologies, Inc.
"See the invisible"
Prev: Variable scan rate Emmanuel Mayssat
Next: Re: Variable scan rate Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Building JCA1 Janet Anderson
Next: A couple of drvAsyn/devGpib questions LYNCH, Damien
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
