Emmanuel Mayssat wrote:
My follow up question is let's assume that I have a device with a scan
rate of .1 sec, but its processing take let's say 1 sec. The device may
or may not be programed as asynchronous.
If it's not asynchronous, then other records in the .1 second queue will
not get processed while this device's record is waiting for a reply from
the device. In this case, you life will suck, and eventually you'll change
the device support to be asynchronous. Let's assume this has already happened.
I use redhat linux, or fedora ( not a real time OS )
let's assume that some records are trying to access the same bus ( but
the bus is most of the time busy ) at a scan rate of .1 sec.
In other words I am trying to do to many things at once ;-)
Now, what happens to the .1 sec epics queue ?
Does it fill up?
Does it crash the ioc?
What happens?
While the (asynchronous) record is busy, the .1 second scan task will
check at 10 Hz to see if it can be processed, find out that it cannot
be processed because it's already busy, and skip ahead to the next
record in the scan queue.
The queue, by the way, is just a list of the names of records that must
be processed, not a list of processing requests. The queue will not
get bigger or smaller unless more records go into or come out of the
scan group.
It seems that even if the records are not conflicting for the same
bus/resource, multi threading doesn't kick in the way I thought it
should. Can I have multi threading on a linux platform ?
If so, the epics queue should never "fill up", but my experience seems
to show otherwise.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- Building JCA1 John Faucett
- Variable scan rate Emmanuel Mayssat
- Re: Variable scan rate Steven Hartman
- Re: Variable scan rate Emmanuel Mayssat
- Filling up epics queue / Multi threading on linux Emmanuel Mayssat
A couple of drvAsyn/devGpib questions LYNCH, Damien
<2006>
2025
Re: Building JCA1 Janet Anderson
<2006>
2025
