1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timestamp record?
To: Jeff Gebhardt <[email protected]>
Cc: Mark Rivers <[email protected]>, [email protected]
Date: Tue, 10 Jan 2006 15:47:16 -0600
Mark Rivers wrote:
Jeff,
All records report back the time when they processed, or more accurately the time when they called recGblGetTimeStamp, which is typically done just before posting monitor. You just need to use the proper channel access functions to retrieve that information.
Jeff,
It sounds to me that you are asking for a string record which contains the formatted IOC time. If so, device support for a string record to do just that is available. Let me know if that is what you want ...
Ned
RE: Timestamp record? Mark Rivers
Prev: RE: Timestamp record? Allison, Stephanie
Next: How to check an external PV from IOC shell Zhou, Jingchen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timestamp record? Andrew Johnson
Next: RE: Timestamp record? Allison, Stephanie
