1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to check an external PV from IOC shell
To: "Zhou, Jingchen" <[email protected]>
Cc: [email protected]
Date: Tue, 10 Jan 2006 16:22:10 -0600
Zhou, Jingchen wrote:
Is there any simple way to check status of an external PV from IOC shell?
For example, I am at a IOC shell
epics>
Is there any IOC shell command (or some way) that allow me do things like "dbpr external_PV" or "caget external_PV"?
Jingchen
I am not aware of any IOC based tools that support this *directly*. It would be a useful utility if you chose to develop it.
However, there is always the hack!
If you have a spare record in your IOC (e.g. a soft AI record) you could ...
dbpf "softAI.INP", "externalPV"
dptr "softAI"
The STAT field will reflect if the external PV was found, the .VAL will reflect its value.
Ned
RE: How to check an external PV from IOC shell Williams Jr, Ernest L.
How to check an external PV from IOC shell Zhou, Jingchen
Prev: How to check an external PV from IOC shell Zhou, Jingchen
Next: RE: How to check an external PV from IOC shell Williams Jr, Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
