1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem about EDM
To: <[email protected]>
Date: Fri, 20 Jan 2006 16:01:10 +0800
Subject: EDM exit problem
I use edm to develop two edl files on Solaris and execute them . One file (parent window)call the other file(child window) to display by RelatedDisplay control object with 12 macros. The two display are all connected to EPICS database running on VME/IOC.
When I try to exit the child window by following:
(1) double click the ico on the top left corner
(2) or single click the ico on the top left corner and select "close"
the edm will corrupt and generate core files.
the error does not always exit, sometimes I use (1) or (2) to exit the child window, it is ok, no problem,
but sometimes it will make edm corrupt.
I wonder what is the reason:
(1) too many macros ?
(2) I should exit by the EXIT control object in edm?
(3) or some others?
Thanks for any suggestios!
Best Regards!
Yuekj
Prev: Re: Cost effective solution for monitoring a large number of temperatures D. Peter Siddons
Next: RE: Timestamp record? UPTIME Miroslaw Dach
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: vxStats like support for linux or RTEMS Phillip Sorensen
Next: synApps workshop part 2 - 20-23 February Rees, NP (Nick)
