1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: R3.13.10 ca_event problem
To: <[email protected]>
Date: Tue, 24 Jan 2006 09:02:53 -1000
Aloha
Finally, 8 years after deploying R3.13.0beta12, we at the Keck observatory are attempting to deploy R3.13.10.
During about 80 hours of testing we have had 3 events of the form “ring buffer overflow” within a CA_event task. On two of those occasions the Vxworks 5.3.1 system (pPC), on which the error occurred  appeared to lose it’s connections to all it’s clients, even other EPICS empowered IOC systems. The events lasted for 7-12 minutes, after which most connections were re-established (at least one channel to another IOC did not reconnect!). On the third such event a CA_event task was suspended and the following was in the iocLog:
tdc2:1040 Fri Jan 20 13:42:39 2006 filename="../taskwd.c" line number=159
tdc2:1040 Fri Jan 20 13:42:39 2006 task 36a5718 CA_event suspended
tdc2:1040 Fri Jan 20 13:43:28 2006 interrupt: ./taskwd.c" line number=159
tdc2:1040 Fri Jan 20 13:43:28 2006 callbackRequest ring buffer full
It so happened that I was monitoring the IOC via a telnet connection, thereby logging the following, which was not in the iocLog:
instruction access
Exception next instruction address: 0x30303030
Machine Status Register: 0x4000b030
Condition Register: 0x42000040
Task: 0x36a5718 "CA_event"^G
interrupt: callbackRequest ring buffer full
Seeing as the instruction address 0x30303030 is outside of the address space…  life does not seem too good.
I was not physically present during this event so I did not get a chance to perform a task trace before the IOC was rebooted.
I really hate to think that there is an errant pointer somewhere.
Any thoughts would be appreciated.
            Al Honey
            Kevin Tsubota
Prev: job opening at DESY Matthias Clausen
Next: Re: Automated ELOG entries from IOC Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: FW: R3.13.10 ca_event problem Jeff Hill
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
