1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Using AAI records under EPICS
To: tech talk <[email protected]>
Date: Wed, 25 Jan 2006 08:58:26 -0500
On Jan 25, 2006, at 05:53 , Bruins, Stefan wrote:
For an application I need to upload a large number of analogue values to a
device. Therefore the AAI record seems to suit perfect.
I use EPICS R3.14.6 on a linux machine.
As being not such an experienced user it is not clear for me how to add the
support for this record to my application.
I've already added the line:
DCCC_DBD += aaiRecord.dbd
After the "DCCC_DBD += base.dbd" line in the "DCCCApp/src/Makefile" file.
When running the application I get the following message from the IOC
console:
	filename="../recGbl.c" line number=88
	Missing device support entry table PV: DCCC:wavgen:waveform  aai:
init_record
What actions do I have to take to get the support for this record type
running?
Hi:
I know nothing about the aaiRecord, but the message indicates
that the database processor read your aaiRecord.dbd file,
knows about the aai record and its fields, yet fails to locate the
library code that actually implements the _device_ support for your aai.
How did you set the 'DTYP' field of your record?
For example, if you set it to
   field("DTYP", "XYZ")
then your dbd file would have to include something like
   device(aai, INST_IO, devAaiXYZ,"XYZ")
and your application would somehow have to include the binary that
implements devAaiXYZ.
-Kay
Using AAI records under EPICS Bruins, Stefan
Prev: Using AAI records under EPICS Bruins, Stefan
Next: Re: Using AAI records under EPICS Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
