After some advice about the use of the waveform record as an output record I
decided to use this record in combination with with a SUB record to write to
all the elements in the waveform record. In my database I made the following
links between those records
waveform.VAL <=> sub.INPA
waveform.FTVL <=> sub.INPB
waveform.NELM <=> sub.INPC
VAL is used as a reference for the start of the array, FTVL is an indication
for the increasement of the pointer to access the next element in the
waveform array. NELM will function as a limit to indicate the range of the
waveform array.
I've already created an .cpp source file but it's not clear for me which
steps to perform to import this file to my EPICS IOC.
Some trial and error only gives me failures during the make process of the
application or a "subroutine not found" error during IOC startup.
- Re: use of SUB record Tim Mooney
RE: Building the sequencer on windows XP Mark Rivers
RE: use of SUB record Bruins, Stefan
<2006>
2025
<2006>
2025
