1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: use of SUB record
To: "Bruins, Stefan" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Fri, 27 Jan 2006 16:26:48 +0100
Stefan,
you should use instead the genSubrecord. In the genSubRecord you have access to the values of other records by pointer, whereas in the subRecord you get copies of the values only.
Burkhard
Bruins, Stefan wrote:
Allright, but which steps to commit when created the gensub conversion
source code. Especially the makefile settings etc...
I include part of my Makefile.Vx:
# Makefile.Vx
TOP = ../../..
include $(TOP)/config/CONFIG_APP
#  ADD MACRO DEFINITIONS AFTER THIS LINE
RECTYPES += mcaRecord.h
DBDEXPAND += ../mcaRecord.dbd
RECTYPES += genSubRecord.h
DBDEXPAND += ../genSubRecord.dbd
DBDEXPAND += ../menuGenSub.dbd
#SRCS.c += ../drvSTR7201.c
#SRCS.c += ../devSTR7201.c
SRCS.c += ../drvSIS3820.c
SRCS.c += ../devSIS3820.c
SRCS.c += ../mcaRecord.c
SRCS.c += ../genSubRecord.c
SRCS.c += ../scalerN.c
LIBOBJS += drvSIS3820.o
LIBOBJS += devSIS3820.o
LIBOBJS += mcaRecord.o
LIBOBJS += genSubRecord.o
LIBOBJS += scalerN.o
LIBOBJS += $(EPICS_BASE_BIN)/devVXStats.o
LIBOBJS += $(EPICS_BASE_BIN)/waitRecord.o
LIBOBJS += $(EPICS_BASE_BIN)/recDynLink.o
include ../baseLIBOBJS
LIBNAME = exampleLib
INSTALLS += iocCore
#Note that the command line that builds the
#library $(LIBNAME) may be HUGE (>3kB)
include $(TOP)/config/RULES.Vx
#  ADD RULES AFTER THIS LINE
I have the waveform record inluded in baseLIBOBJS
In my case I have a mcaRecord which collects data from an array of multi-scalers, the data are stored internally in waveforms, then my
gensubrecord action routine in scalerN.c/o reads the arrays and calculates means and all sorts of things and then stores the data again in output waveforms.
Hope, that helps,
Burkhard
RE: use of SUB record Bruins, Stefan
Prev: RE: use of SUB record Bruins, Stefan
Next: Re: use of SUB record Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Next: FW: use of SUB record Bruins, Stefan
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
