1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: C++ compiler versions
To: EPICS tech-talk <[email protected]>
Date: Fri, 27 Jan 2006 12:36:07 -0500 (EST)
A point of information for others upgrading EPICS versions. The latest
3.14 versions of base require a newer C++ compiler then previous versions.
The old gcc-2.95 which I had succesfuly used to compile 3.14.4 and earlier
cannot handle the C++ code in libCom 3.14.8. I also had problems in the
linking stage of C++ modules trying to use SUNWspro-6.0.1, also in libCom.
I switched to gcc-3.4.5 and everything builds fine.
This is for the host compiler, not cross-compiler. My build host is
Solaris-8 sparc.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
RE: C++ compiler versions Jeff Hill
Prev: control systems and relational databases Claude Saunders
Next: RE: C++ compiler versions Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
