1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: enhanced seq record
To: "Brian McAllister" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Mon, 30 Jan 2006 14:18:01 -0600
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Brian McAllister
> Sent: Monday, January 30, 2006 1:17 PM
> To: EPICS tech-talk
> Subject: Re: enhanced seq record
> >>> On 1/30/2006 at 12:16:55 +0100, Luedeke Andreas wrote:
>> Of course the same can be done already with "calcout"
> chains.  But a single record to control a sequence would simplify
matters.
> The calcout record is also one of the largest because it has
> all the calc code in it, thus being very inefficient if you don't
actually
> need to calc anything.
> I use seq or simple soft output records instead of calcout wherever
> possible for that reason.
But there is only one copy of the code for calcout in the entire IOC,
right? calcoutRecord.o is only 12kB on a vxWorks-ppc604, so it does not
seem very inefficient to me.  The size of struct(calcoutRecord) is a
little bigger than struct(aoRecord), but not by a large amount.
Re: enhanced seq record Brian McAllister
Prev: Re: enhanced seq record Brian McAllister
Next: Re: enhanced seq record Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: enhanced seq record Tim Mooney
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
