1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: striptool channel names
To: Albert Kagarmanov <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Fri, 03 Feb 2006 09:23:09 +0000
thanks, that got it. Turns out I was using version 2.4.3 whilst reading the latest documentation.
Getting it to build was interesting. I had to change some deferred assignments to immediate assignments in the Makefile.Host - STRIP_HISTORY and HAVE_XMU.
Cheers
Ian
Albert Kagarmanov wrote:
		Hi Ian,
	It's depend from version of StripTool which you're using now.
In Argone web-page http://www.aps.anl.gov/epics/extensions/StripTool
you can download Strip_Tool_2.5.10.0, which can display
.DESC-field in legend-panel (right part of main screen)
I.e.
http://www-kryo.desy.de/documents/EPICS/DESY/General/Archiver/DesyStripTool/StripTool_New_Features.jpg
"Endcap II Druck 0-100mbar"
"TVC2SP1R3 Saugdruck RM-Trans"
"TVC2SP1R99 Anlagen-Ausgangsd"
"VC2ICP: PLC 0 connection"
"TVC2TP1R1 Saugdruck Leybold"
- is descriptions from IOC
	This extension of StripTool was developed and used here (DESY)
since  1998.
And as far as I know, it's currently supported by Argone (Ken Evans) as
well.
Albert Kagarmanov
MKS-2, DESY , Hamburg, Germany
I've just started using striptool so the following is probably a newbie
question:
Striptool is only displaying the epics channel names for each line, it's
not displaying the descriptions I have in each of the DESC fields of the
records.  Is there something else I need to do the get the descriptions
displayed on the graph?
TIA
Ian A Smith               Telephone: +44 (0) 131 668 8255
Royal Observatory         Fax:       +44 (0) 131 668 8314
Blackford Hill            Web:       http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
Edinburgh
EH9 3HJ
UK
striptool channel names Ian A Smith
Re: striptool channel names Albert Kagarmanov
Prev: Re: Cost effective solution for monitoring a large number of temperatures Josh Stein
Next: 1-wire device driver Jon Brinkmann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: striptool channel names Albert Kagarmanov
ANJ, 02 Sep 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
